| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 10 Member | | Member Joined: Nov 2002 Posts: 10 | The oiling tube that comes off of the head and runs up to and around the center of the rocker arm rack is broken off. How important is this tube? Do I need to replace it? The engine is a 54 235.
46 GMC
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | It may look broken off but isn't. It kind of ends and I believe is crimped at the end on the 54. You mean underneath the valve cover right?
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Nov 2002 Posts: 10 Member | | Member Joined: Nov 2002 Posts: 10 | You're right... it is crimped off. I used to have a 216 and that tube ran right around, with-out a crimp. Is the tube even needed?
46 GMC
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The earlier type of tube just went up from the head to the ring between the rocker shafts and wrapped around. Then it just pointed down toward the head. The one you have will be fine as being pinched off, it allows a little more oil into the rocker-shaft.
