0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | I'm finally working on getting the bed done on my truck('53 3600)and ran into a problem. I bought replacement bed aprons about a year ago and went to put the brackets on today and they don't seem to be right. I threw out the originals two years ago because they were shot(i know rookie mistake). Here are a couple pictures of my problem. http://i55.tinypic.com/16jf04h.jpghttp://i55.tinypic.com/2wewfo1.jpgAny thought? I searched and bed aprons don't seem to be mentioned often. | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Could it be you have 54 and later aprons? I just know they are different.
joe
1955 First Series 3100
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Could this just be another example of poor quality aftermarket panels?
It looks like they could be 'persuaded' to fit. Have you tried to pull the apron lip over to the bolt hole in the bracket?
Unfortunately most panels now have to be 'modified' in some way to acheive a good fit,although I would have expected yours to be a bit closer than they are. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | I would fit the splash aprons to the bed and running boards first to make sure they are correct and make any changes so they fit right. Then rework the support brackets, no point in reworking the brackets first if the aprons don't fit. | | |
