Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (TexasJim50, rick46ia, cmayna, Southerntruck, SNOYL, ShopRag, Mike Roache), 45 guests, and 1 robot.
Topics128,006
Posts1,055,271
Members48,418
#735698 04/02/2011 11:12 PM
Does anyone know if someone makes a floor pan patch for a '65 C10 that would replace the area where the floor high beam headlight switch is? I haven't had much luck finding one myself.
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
Nesto426 #736141 04/04/2011 4:18 PM
check out the LMC book
Banjoe #736170 04/04/2011 6:15 PM
Banjoe,
Sure wish it would be that simple. Can't find the toe board anywhere. Wouldn't be a problem except for the foot operated headlight dimmer is indented there from the factory.
Tom
Nesto426 #740736 04/19/2011 10:34 PM
tracern1 #740802 04/20/2011 2:18 AM
Thanks Tracern1, still not it. I am totally convinced that they do not reproduce that section for the '65 trucks. I can find the front floorboard everywhere but not the toe board. It is the piece just ahead of the front toe board where the dimmer is located.
I do have someone sending me an original from a cab.
Tom
Nesto426 #740878 04/20/2011 8:35 AM
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=20
Is it here? If not then your probably correct and its not made.
Next option is to get the sheet steel and make it your self, or find a good sheet metal body guy to make it.
http://www.brotherstrucks.com/prodinfo.asp?number=FRP5900%2DT
Looks like the other guy got it with the brothers site. Is this the panel?
Thanks guys. Truck Item 2 and 3 only go up to the seam that begins the toe board. The toe board is above that. I took a couple of pictures of it here: http://s1094.photobucket.com/albums/i442/nesto426/Floorboard/
Thanks again guys.
Tom
Nesto426 #741382 04/21/2011 10:13 PM
strange that they don't make the patch panel for that area. looks like it shouldn't be hard to weld back in though once you get the repair panel, good lick.
