| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Does anyone know if someone makes a floor pan patch for a '65 C10 that would replace the area where the floor high beam headlight switch is? I haven't had much luck finding one myself.
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Apr 2011 Posts: 11 New Guy | | New Guy Joined: Apr 2011 Posts: 11 | | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Banjoe,
Sure wish it would be that simple. Can't find the toe board anywhere. Wouldn't be a problem except for the foot operated headlight dimmer is indented there from the factory.
| | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Thanks Tracern1, still not it. I am totally convinced that they do not reproduce that section for the '65 trucks. I can find the front floorboard everywhere but not the toe board. It is the piece just ahead of the front toe board where the dimmer is located.
I do have someone sending me an original from a cab.
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=20Is it here? If not then your probably correct and its not made. Next option is to get the sheet steel and make it your self, or find a good sheet metal body guy to make it. http://www.brotherstrucks.com/prodinfo.asp?number=FRP5900%2DT Looks like the other guy got it with the brothers site. Is this the panel?
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Thanks guys. Truck Item 2 and 3 only go up to the seam that begins the toe board. The toe board is above that. I took a couple of pictures of it here: http://s1094.photobucket.com/albums/i442/nesto426/Floorboard/Thanks again guys.
| | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | strange that they don't make the patch panel for that area. looks like it shouldn't be hard to weld back in though once you get the repair panel, good lick. | | |
