| | | Forums66 Topics128,105 Posts1,056,542 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 7 New Guy | | New Guy Joined: Mar 2011 Posts: 7 | I'm starting to work on a friends 54 chevy 6500. its a great looking truck and cant wait to get it on the road. Its got a few issues, some electrical, some body, but mostly transmission. I hope I get all the info i need. im looking forward to talking to you guys in the future.
If it aint broke, get a different project.
| | | | | Joined: Apr 2006 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 48 | welcome. I would hate to work on a 60 year old rust belt truck! Keep in mind you may be way ahead of the game by finding a used transmission rather than dumping a lot of money into the one you already have. Have fun! | | | | | Joined: Mar 2011 Posts: 7 New Guy | | New Guy Joined: Mar 2011 Posts: 7 | the trucks pretty rust free, the frame must have been cleaned and painted recently too. what transmission should i be looking for? this one has a PTO, but the dump bed has been replaced with a flatbed so i wont be needing that on a replacement.
| | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | Welcome to the bolt. This is a great place for information. If the truck has a 4 speed transmission in it, It will most likely be a SM420. This transmission was used from late 1947 through 1967. It is a great transmission. It is very popular with ones building rock crawlers. The PTO was an add on unit, and should have a cover on the side of the transmission where it bolts on. Have fun. Jim | | | | | Joined: Mar 2011 Posts: 7 New Guy | | New Guy Joined: Mar 2011 Posts: 7 | So it should'nt be hard to find a replacement, thats good. From what I remember those are nearly impossible to break so that probably isnt the problem. most likely something went wrong with the clutch. my friend said after the clutch was replaced he started it, put it in gear,heard a big bang and now nothing. im gonna drop the trans and check that out. Is the PTO deletable without ruining the trans?
| | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | The PTO should be bolted on from the outside. It can be removed without removing the transmission. If it has a drive line still attached to it, you may have to remove it or disconnect it. Jim | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | If you are not going to use the hoist, you might as well remove the PTO if you can find a cover for it. | | |
