7 members (55shaker, dt235sd, Hanks custodian, NJC, 3B, Gdads51, 1 invisible),
211
Mod | | | Forums66 Topics128,086 Posts1,056,098 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | I want to put headers on the 283 in my 57, but I'm worried about clearing the steering gearbox. It seems like the longer tubes would be extremely close to the gearbox, and either require bending, or it would heat up the grease in the box from being to close.
Anybody have any tips or ideas which headers would fit better?
Alex 57' 3100 (The Bondo Bandit) Bad rust and worse wiring, but so much fun.
| | | | | Joined: Jan 2011 Posts: 11 New Guy | | New Guy Joined: Jan 2011 Posts: 11 | I have headers on my 57, it also has a 283. They are long tube with no clearance problems. I put them on back in 1979, if I remember correctly I couldn't get them for a 57. I think they were for a 73-79 chevy truck. Hope this helps. Steve
1957 Chevy 3100 Graduation Present from Dad in 1978 Steve
| | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | sounds good. Ive seen some pics where the headers go pretty darn close to the steering gearbox, ever hear of the lubricant in the box getting to hot changing the viscosity in a bad way?
| | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | I used a set of Sanderson shorty headers in my '56 with a SBC, they worked out great with lots of clearance. Should mention mine had a mustang II rack and a late model steering column. | | | | | Joined: Sep 2010 Posts: 11 New Guy | | New Guy Joined: Sep 2010 Posts: 11 | what was the part number on those Sandersons | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I have Corvette headers - center dump, no clearance issues. | | |
