1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 27 | Are there any major differences between 3100 frames from 47 to 54? Body mounts and drive train mounts the same? I have a cab and front fenders from a '54 1-ton truck I'd like to adapt to a 1/2 ton frame. Should I be looking for a '54 1/2 ton frame? Or will an earlier frame work? Thanks for any advise. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I am not sure about the cab mounts being different, but I think it should mount to any of the frames easily enough. It's the beds that are different. The 19475/3 frames are different from the 1954/55 frames, there is no arch above the rear-end on the 54/55, it's virtually flat. The front fenders should fit too. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Crossmember at the transmission is different, the 54 uses angled mounts on the bellhousing. However you could easily swap bellhousings to put your Stovebolt in either early or late frame.
From what I know and for what you want to do any 47-54 frame should work. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | The cab mounts will change around 48-49. The earlier cab mounted in the center on the earlier and changed to the two side attachments either in 49 or 50
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | In addition to the above the 47-through Mid 49 frame has lever action shocks and related brackets. | | | | | Joined: Jan 2010 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 27 | Thanks for all the help guys. Sounds like least path of resistance is to find a 54/55.1 frame. Maybe I'll spot something I can use at the Portland swap meet this weekend. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I just deleted two posts by helpful people with tips on finding a frame. Such tips need to be sent by PM. We don't want to turn General Truck Talk into a swap meet.
Thanks for understanding.
Charlie | | |
