7 members (DavidBraley, Otto Skorzeny, J Lucas, 66flea, Rosco, 55shaker, 1 invisible),
122
Mod | | | Forums66 Topics128,283 Posts1,058,504 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 64 | Is anyone running an s-10 rearend in there 41 to 46 half ton frame?I was wanting to use 55 to 62 pumpkin and use my original housing and axles as I am going back with a t-5 trani,But I have noticed there a lot of s-10 rear ends with low mileage at a fair price. As always thanks for your advice Longhorn | | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | I have a disc brake rear end from a 2002 4wd S10 Blazer in my 1939. It measured exactly the same width as my stock rear end, which is what I wanted. All I had to do was move the spring perches for installation. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Measure,Measure,and Measure again. | | | | | Joined: Nov 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 64 | Alkay3 Could you tell me what gears you are running in your s-10 rear end? Thanks Longhorn | | | | | Joined: Dec 2005 Posts: 13 New Guy | | New Guy Joined: Dec 2005 Posts: 13 | I am running a S-10 rear in my 41, you do need the 4x4 rear end. I checked a lot of them for their gear ratios, a lot were 3.73, but some were 3.08. seemed to me the 3.08 gears were in the latter trucks, with the 4.3 motors. At least that's the way it seemed to me. I used the 3.73 in mine, w/ a T-5, and 261, works great.
That's good, tighten it up till it strips, then back it off a quarter turn!
| | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | Longhorn, Mine is a 3.42 ratio. This with the 270 engine and T5 transmission seems to work well. | | |
