0 members (), 83 guests, and 0 robots.
Topics128,049
Posts1,055,740
Are there any major differences between 3100 frames from 47 to 54? Body mounts and drive train mounts the same? I have a cab and front fenders from a '54 1-ton truck I'd like to adapt to a 1/2 ton frame. Should I be looking for a '54 1/2 ton frame? Or will an earlier frame work? Thanks for any advise.
1954 Chevy 3100
"Jagrolet
More pix on my website
1953 f100 w/ v8
1953 f250 w/ v8
I am not sure about the cab mounts being different, but I think it should mount to any of the frames easily enough. It's the beds that are different. The 19475/3 frames are different from the 1954/55 frames, there is no arch above the rear-end on the 54/55, it's virtually flat. The front fenders should fit too.
Crossmember at the transmission is different, the 54 uses angled mounts on the bellhousing. However you could easily swap bellhousings to put your Stovebolt in either early or late frame.
From what I know and for what you want to do any 47-54 frame should work.
1952 Chevrolet 3800 pickup
---All pictures---
The cab mounts will change around 48-49. The earlier cab mounted in the center on the earlier and changed to the two side attachments either in 49 or 50
Dennis
In addition to the above the 47-through Mid 49 frame has lever action shocks and related brackets.
Thanks for all the help guys. Sounds like least path of resistance is to find a 54/55.1 frame. Maybe I'll spot something I can use at the Portland swap meet this weekend.
1954 Chevy 3100
"Jagrolet
1953 f100 w/ v8
1953 f250 w/ v8
I just deleted two posts by helpful people with tips on finding a frame. Such tips need to be sent by PM. We don't want to turn General Truck Talk into a swap meet.
Thanks for understanding.
Charlie
