1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#734419 03/29/2011 7:42 PM
... and a truck question. See the pic below (yellow circles). On the driver's door there is a hole with no screw in it while the screw is present on the passenger door. Behind the hole on the driver's door there appears to be nothing to hold the screw. What is behind the panel or at least what should be behind the panel/hole? On the same topic, since the screw is missing, where can I pick up clutch head screws to replace it? Thanks!
Missing screw pic
1946 Chevrolet 1/2-ton
More pix on Photobucket
I don't have one but I wonder if this is for the armrest.
1951 1 Ton Completed
Thanks TruckerNix. I wondered the same thing as there is a parallel height screw about 12 inches back toward the seat, but, I believe it would interfere with the inside door 'open' handle and I have not seen one with factory armrests tho anything is possible.
Armrests or handles? I know some vehicles had inner pull-handles (like suitcase handles) that would flop down when not in use. Others had a plastic strap that slid in and out of the end holders, so it would sit flush when not in use, but give some finger space to grab and pull the door closed (possibly saving wear on the latch handles)
I just went and looked at my '40 and those are self-tapping screws that secure the inner door panel to the cross brace in the door.
There is a space between the panel and the brace, perhaps the reason it seems nothing is behind the hole.
As for replacing the screw, I'd take one from somewhere else (like
behind the seat) and put a phillips back there!
Hope this helps.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
I just finished putting my door panels on. Those holes (on my 46 at least) take the same clutch head screws as most of the rest of the interior. They attach to the panel that holds the window regulator and door latch on top, and the lower one attaches to the brace that holds the window bump stop. I assume they are there to keep the door panel from rattling.
