| | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 9 New Guy | | New Guy Joined: Aug 2007 Posts: 9 | Does anyone have any ideas on why my 51 leans to the left. It is not just the cab it is the cab and bed together. If I push it up on the left side it will stay untill weight is put back on the left side. Any ideas will help. Thanks | | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Sounds like your suspension is a little "sticky" or possibly weak on that side. Take some measurements (springs,shocks,links) and compare to the right side. Also check the spring pins and bushings (and respective mounts). How much is it leaning? | | | | | Joined: Jan 2011 Posts: 11 New Guy | | New Guy Joined: Jan 2011 Posts: 11 | Like tcox said it may be sticking. Also check your springs for a broke one. I have seen a broke spring act like that. Steve
1957 Chevy 3100 Graduation Present from Dad in 1978 Steve
| | | | | Joined: Mar 2011 Posts: 65 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 65 | Funny my bed leans a little, but my cab is straight. Always just figured as long as everything is secure, its just an old truck.
Im pretty into off-roading, and have a Jeep Cherokee. It has leaf packs in the rear. When you install big leaf packs for big lift, they always seem to lean over time. usually swapping the leaf packs around solves the problem. Maybe if both your packs are in good shape, try swapping them.
1951 1/2 Ton 216ci 4spd 1955 3/4 Ton NAPCO 235ci 4spd 1959 1/2 Ton stepside 235ci 4spd
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The original owner was probably a big guy. That caused them to lean to the left. The springs on the drivers side probably need re arching. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Have a look at the angle of the shackles on each side to see if they are different. That can give you an idea of which pack is sagging more. | | | | | Joined: Aug 2008 Posts: 38 'Bolter | | 'Bolter Joined: Aug 2008 Posts: 38 | The original owner was probably a big guy. That caused them to lean to the left. The springs on the drivers side probably need re arching. You think he is joking but there is more truth to that than anything else. Look at any older truck or car for that matter that is normally driven by one big guy with no passengers riding with him and it will lean a bit to the drivers side. Having or rearching the springs so that all of the springs matched in arch would fix the problem. When I was doing front end work in the 70's I would have to put AC spacers on the springs on the left springs of some Pontiacs that had heavy drivers and sagged on that side.
48 Chevy 3100 going back together with a 292 six and AX15 five speed.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | My truck leaned to the left because the kick panels had rusted away from the floor which is typical on the old truck. the floor had buckled from no support and i had a bulge in the floor.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
