| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | i have to bend my hinges on the new door that i put on my truck because the bottom of the door sticks out. the old door did not have this problem, would i be able to get around bending the hinges by just replacing the new lower door hinge with the old lower one? i think the two trucks were different years because of different vin plates (one was blue the other black)but they are both vent windows 1953/52 3100 | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I believe the hinges themselves are the same. Sorry, I can't help on the adjustment. I got lucky on mine. | | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | well i knew that the hinges are the same, but i was wondering if the old ones that made the old door line up right would make the new door line up the same as the old door. As in the old hinges are bent the right amount due to over time or factory | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | once removed you may still have a problem getting them aligned again. I know its to late for now but a lot of bolters say drill small holes in the hinge/pillow and put a small roll pin in it as that is the only way to make sure hinges go back in the same place...... It seems there was a tip here in the Tech Tips section about adjusting doors? Worth a check. Let us know how you make out. Sorry I can't help any better. | | | | | Joined: Sep 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 46 | Does anybody know where the Info on Hinge bending to make the doors fit better the rear of my doors fit great but with the new cowls the front of the door sticks out a bit to much for my likeing
Jaime | | |
