0 members (),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Hello, I purchased a rebuilt electric wiper motor for my 55.2 Chevy truck. It only has one brown wire. Should it have a ground wire or is the body of the motor grounded when bolted in? I sanded off all paint where it mounts and connected the "wiper motor" wire (aftermarket wiring harness) and switched the motor on and nothing happened. Any ideas? I get a little spark when I connect the power wire if that means anything. | | | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 63 | intrigued with that , one wire ? usually has 2 which the switch changes polarity to reverse the motor. have you tried connecting the motor up does it go one way with 12v on the brown wire and an earth on the motor frame ? if so try grounding that brown wire and place 12v positive onto the case of the motor. doing this on an insulated surface i.e timber bench what happens? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | bad unit? there is only one brown wire on the original and the case is the ground via the small sheet metal brace on one end [the main mount has grommet cushions on the 2 bolts] - the spark means power is finding ground .... did it come with the control attached? maybe that cable needs adjusting where it connects to the control, did you try it on the bench or mounted?
Bill | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I tried it mounted in the truck. Guess I thought a rebuilt motor would work! BTW, the grommets where it mounts on the top were disintegrated so I just took that down to bare metal as well.
I hooked up the cable and it seems to click to the on position, but that is a good idea to double check that.
If I test it out of the truck do I simply hook up a wire to the + side of a battery and ground the - side to the body of the motor? I don't want to fry this thing! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, you can just clip a wire from the body of the unit to ground and then touch the lead wire to the + with the switch in one position then change the switch and touch the + lead again ... hold the motor so it doesn't jump, they do have some torque .... and there should be 3 positions of the switch, off, on, high
you do want to have those rubber grommets on the mount or it'll drive you crazy with the noise humming thru the body metal
Bill | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Bill, I'll give it a try tonight. Though I must say, I only recognize one "click" when moving the cable, even if I move it by hand. Doesn't seem like three?
Do you know where to get those grommets?
Thanks for the advice! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I'd have to try one on the bench to see the sound and feel, but they are a 2 speed motor so there's 2 "on" positions, the high speed one may not be noticeable .... I'd look at a FLAPS for the grommets, should be able to find some to fit in an assortment
Bill | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | So I left the motor in the truck and ran two wires directly from the battery to the motor. I grounded the motor housing and touched the + wire. Got a small spark and nothing. I manually moved the lever and nothing. So, I guess it is a bad unit. Hopefully Classic Parts will replace it as I bought it over a year ago. | | |
