0 members (),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73334 02/16/2007 4:02 AM | Joined: Feb 2007 Posts: 13 Junior Member | | Junior Member Joined: Feb 2007 Posts: 13 | I have 2 1953 GMC pickups,I will be making one from both.These are Canadian trucks which are basically chev trucks as they have the 216 engine.My question is which engine is best as I have a GMC 248 and a GMC 302.Iis this a difficult swap? also will the 248 clutch housing fit the 302? thanks for any info | | |
#73335 02/16/2007 4:18 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The 302 is the holy grail of GMC sixes. Finding blocks can be a problem. I don't know about the bell housing. The 248 is a good engine, in it's own right. If I were wanting to put a GMC six in a truck, I would get a 270. Blocks are a lot easier to find than the 302.
Fred 52 3600 69 C-10
#73336 02/16/2007 4:27 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy masseyharris, bellhousings interchange within the G.M.C. line 228 236,248,256,270,302, and across to the Chevy line 216,235,261. The G.M.C. engine is longer than the Chevy, so adaption or crossmember replacement will be necessary, also the rad. will have to be relocated, hope that helps. | | |
#73337 02/16/2007 6:15 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I've looked into a 302 a little bit. They aren't that hard to find, but they are expensive to rebuild, especially to warm them up. My current pipe dream is to wait a few years till my son gets older and hot rod a '39 or '40 pickup w/ a 302, 5spd and a F@#d 9" rear. At 3 1/2 he's pretty much into cars and trucks, especially trucks. | | |
#73338 02/16/2007 4:35 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Best is send me the 302 and keep those Canadian trucks completely original with their Chevy motors.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#73339 02/16/2007 11:32 PM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Along this same line; how hard would it be to bore out a 248 to make it a 270, and are the cranks the same? | | |
#73340 02/17/2007 7:15 PM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | The 248 has a shorter stroke... I think 3 13/16 of an inch. The 270 and 302 had a 4 inch stroke. It was popular to put the 248 short stroke crank in the 302s to reduce friction and rev higher. Some torque would be lost, and some upper range performance would be gained.
Putting a 270 crank in a 248 would basically give you a little bit more stroke and increase torque. I'm not sure how many cubic inches you would pick up. | | |
#73341 02/17/2007 7:19 PM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Hey bigmacdaddy... That is exactly the project I am working on now... 1940 gmc, 302 with a nv4500 5speed and f@rd 9 inch rear with 4.11 posi. I hope it comes together in person as well as it sounds on paper! | | |
#73342 02/17/2007 8:17 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | That's awesome and weird. 1st the name and now this. You would think I was copying you. Great minds must think alike. How about some pics? | | |
#73343 02/19/2007 6:46 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I've got a 302 also, just picked it up last month. It's going into my '50 Chevy with a 4 speed saginaw and 3.07 rearend. I'll be fuel injecting it after I get it running and set up. It has a 2bbl Holley and a governor on it right now. It runs but smokes a bit.
