8 members (2-Ton, DadsFirstPickup, 32Fordpuchoptop, FAST55, Otto Skorzeny, mason86, rfs56trk, TexasJim50),
73
Mod | | | Forums66 Topics128,049 Posts1,055,661 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I've built a tank out of plywood and lined it with plastic, filled it with water, added baking soda, installed cab, connected battery charger, drawing about 8 amps, that's the most I've ever seen drawn. It varies in how close the cab is to the anode. I only have the cab half submerged, working fine, water is really dirty, I've been lifting it out and cleaning with a toilet brush, really getting the rust off. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: May 2005 Posts: 119 Shop Shark | | Shop Shark Joined: May 2005 Posts: 119 | Wow! Keep us posted, Please show some pics too. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Baking soda may work but laundry soda is the preferred additive. | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | like cletis says, try wash soda (Na2CO3) instead of baking soda (NaHCO3) for higher ionic strength => better de-rusting efficiency | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I can't wait to see some pictures of it. That is quite amazing! | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I'm working on the pictures, while we're here I have a question. Is there any reason not to paint most everyting on the cab, not the exterior, with por-15. Where can I get wash soda, I've never seen it. Dave
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Arm & Hammer washing soda is in the laundry section of yer supermarket [why you've never seen it?  ], it's a water softener sometimes called Sal Soda - also used to control pH in pool water if you've got a pool supply place around - it's sodium carbonate, baking soda is sodium bi-carbonate, which will work, but needs more of it and takes longer Bill | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Can I just add the washing soda to what I have now or is that bad? What's in the tank now looks like it's a super fund site, kinda blue/green maybe, real nasty but working. Dave
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | normally adding more doesn't improve the action, and the function shouldn't be affected by how much sludge collects, if it's working well, carry on - AFAIK the sediment isn't toxic, and can mostly be filtered out by running the water thru something like cheesecloth without affecting the function
Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Those photos are really something. Those cabs are a lot of work cleaning them with other methods and you can't get it all. | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Keep in mind that it only works "line of sight" between the electrode and the anode so you might have to move the anode around to get every spot derusted. I'm pretty sure you already know that though. It looks like you have a good handle on the situation.
Let us know how it comes out. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I'm going to have to move it to inside the cab to do a good job in there, now it's on the bottom of the tank and not doing as much as it was earlier, amperage is down to about 6, it was as high as 9, I've looked at it several times and it's getting much better, I take the toilet scrubber to it and that seems to help also. I just need to figure out how to turn it upside down next, I will have to get my kids to help me. If I were to do it again I would make the tank a little bigger, the cab just barely fits in. When I'm done with the cab I'm going to float the gas tank in it, tank has some rust on the bottom. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Dave, I use old rusted seat frames for my electrode. Due to the large amount of surface area available it derusts your part quite quickly. When its so rusted it slows down a good deal, you just pull it out and drop it on the ground a few times. the bounce of the springs knocks almost all of the rust off and you can use it again. I usually do that several times until the seat frame breaks into pieces. Ive got a pallet of old seat frames lying around just for this.  Bill mentions above that the sediment isnt toxic, but I'd be leery. You'll be dealing with a bit of lead from the old body seams plus the paint residue that flakes off. Best to just wear gloves. Jeff | | | | | Joined: Feb 2011 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 29 | Just icked up a small kiddie pool to remove some rust on acouple of NOS 54-55 front fenders. It'll go on top of some old carpet in the garage-just need to ventilate otherwise it would make for a lot of explosive hydrogen gas. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | here's the best article I've ever seen about the process, from a "vintage hand tool preservation" association - covers a lot of the details well Bill | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | I've been using electrolosis for some time now on small parts - up to approximately 15 gallon capacity. I have found that if the part has rust, grease, and paint on it, and you want all three removed, sodium hydroxide (lye) is your best bet. $10/gallon at walmart or home depot. Sold as septic main line cleaner in the plumbing section.
However, this one may increase your toxicity a bit. Wear gloves, apron, and goggles. And keep your mouth shut! | | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | Homer I am impressed by your Red Green invention as we say here . I think you my need more duct tape for your dipping pool. All jesting aside yours is a method that many will decide to follow. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I'm back with a report on how it turned out. It exceeded my expectations, I can't believe how well it worked. I'm convined that it's the best way to derust, if you have the time, space and equipment to do it. Making your own tank was easier than I thought, I would make it slightly bigger next time. I was concerned about not putting a floor in it, but it worked fine, I would just double up on the plastic liner. I would also come up with an easy way to pull the anode and clean it. I had a piece of grader blade laying in the bottom and it seemed to loose it's affectiveness after awhile, but I was afraid to move it for fear of tearing the plastic liner. I then took a piece of 2 inch pipe and made hangers for it and hung it between the door holes on the cab, easy to put in and take out and a sinch to clean. If sodium carbonate works better than sodium bicarbonate I might be even happier. Hope this might help anyone who is considering using this method. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Very awesome endeavor. Congratulations on the success. This is a new benchmark for do it yourself bolters! | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | It wasn't that tough to do, you just need an overhead hoist or some means to lift it out of the tank. The tank was pretty easy to make with the used plywood and 2x4s, I don't know if I really needed all the reinforcements I used, it didn't fail so maybe I did. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Does this remove paint? And RNuts, are you saying that the lead seams will be removed by electrolysis as well? | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | It didn't bother my leaded seams. Any paint that is not real good or has rust under it will peal off real easy or just fall off. I would say about at least half of all paint came off, when I pressure washed it more came off. It is unreal how clean the cab is now, it REALLY is a good way to go, I'm ready to start my repairs now. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Does this remove paint? And RNuts, are you saying that the lead seams will be removed by electrolysis as well? No, but just like any metal, lead will also oxidize. The process of electrolysis removes any oxidized metal, leaving alone the clean metal beneath. As an example, if you put a piece of oxidized copper with a nice bluish-green patina in there, it would remove that discolored oxidized metal leaving a nice shiny piece of copper behind (once you scrubbed it and washed it off). The lead can also be in the paint. Every piece Ive ever done, the paint has softened and sloughed off with a wire brush or scrub pad. Jeff | | | | | Joined: May 2005 Posts: 119 Shop Shark | | Shop Shark Joined: May 2005 Posts: 119 | I have a few more things to remove from my son's cab, then I can start building the dipping tank! I can't wait to try this! Ted. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I would make sure that I had a way to remove the anodes and clean them during the process, I think it went much faster when they were not covered with a bunch of rust. I took a piece of 2 inch pipe and suspended it through the door openings by hanging it on the walls of my tank. I think it made things go faster. It seemed the more anode I had the higher the amperage. The highest amperage I saw was 11-12 amps. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
