8 members (1955 1 Series, NJC, WICruiser, 51sub, greenie-reddy, Peggy M, Tronman, Gray_Ghost),
120
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | Trying to get the '50 together and I need a gut check. I'm in the process of mounting the front bumper. The brackets have a slight curve and I believe the brackets should curve down. Is this correct? Next, as I've seen in the posts the brackets are a bear to fit and mine are no exception. My question is can the brackets be heated up to bend them to fit? The brackets feel like spring steel and I wasn't sure if heating is an option. I need to bend 1 bracket away from the fender about 1.5 inches to get the fit I need. Tried a come along but the thing just keeps springing back even with some aggressive force. Any other suggestions? Thanks.
It never costs more to ask and it never costs more to think big.
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I would use "heat" as a last resort. The brackets will bend, the trick is to get them to bend right where you need it. I've used a "cheater" bar/pipe & chain, and the comealong. When bending, you have to go past a point to allow for spring back. Hopefully your brackets aren't to bad, and only need a little tweaking. | | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | Yes on the curve down question. Also, I feel your pain. I did a ton of bending and fussing on my bumper brackets to no avail. Finally gave up and bought a pretty decent pair at a local swapping meet.
Have you tried bolting the bumper and brackets up very loosely and drawing things up with the bolts? Maybe even using longer bolts then swapping out to the correct length. How about bolting one side up and using a long steel rod (or dare I say long screwdriver) through the bolt holes to pry the bumper into alignment with the second bracket?
Best of luck. | | |
