3 members (Otto Skorzeny, 1955 1 Series, Wheelie), 165 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
#733279 03/26/2011 5:26 AM
I am going to rebuild my old seat in my 59 Apache. The seat has some rust on the springs. What harm will I do to the springs by blasting them? What would be a good material for the cover? Is their a good source for buying new springs?
Larry
haven't seen the individual springs or the assembly available anywhere - sandblasting could heat the spring steel too much, I'd suggest a rust converter treatment instead - I've used the plain vinyl the local upholstery shop has for covers, close to original
Larry - I had the same deal with my 1953 bench seat to clean out the mouse droppings and resolve some surface rust and broken springs. Ordered the springs at www.diyupholsterysupply.com. To remove the surface rust made a particle board and Visqueen Plastic Box then soaked the springs in a deluted solution of Klean-Strip Phosphoric Prep and Etch(Home Depot). Then I pressure shot it with water - painted. Not sure on the cover material for your 59 Apache.
Your not trying hard enough if you don�t screw up every once in a while.
52 1/2Ton 235
Moderated by  ndkid275, Phak1
