| | | Forums66 Topics128,088 Posts1,055,995 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | I am going to rebuild my old seat in my 59 Apache. The seat has some rust on the springs. What harm will I do to the springs by blasting them? What would be a good material for the cover? Is their a good source for buying new springs? Thanks Larry | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | haven't seen the individual springs or the assembly available anywhere - sandblasting could heat the spring steel too much, I'd suggest a rust converter treatment instead - I've used the plain vinyl the local upholstery shop has for covers, close to original
Bill | | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | Larry - I had the same deal with my 1953 bench seat to clean out the mouse droppings and resolve some surface rust and broken springs. Ordered the springs at www.diyupholsterysupply.com. To remove the surface rust made a particle board and Visqueen Plastic Box then soaked the springs in a deluted solution of Klean-Strip Phosphoric Prep and Etch(Home Depot). Then I pressure shot it with water - painted. Not sure on the cover material for your 59 Apache.
Your not trying hard enough if you don�t screw up every once in a while.
52 1/2Ton 235 | | |
