3 members (1955 1 Series, TUTS 59, baldeagle), 106 guests, and 2 robots.
Topics128,037
Posts1,055,470
Members48,424
#733270 03/26/2011 4:04 AM
Does anyone know what the model number is or what it is refered to for the transmission in a 1940 1.5 ton truck. The casting number is 590474 SN#9088I33. It is a four speed with the thumb lock out for the reverse. I would like to find out any info so I can attempt to mate this up to my new 292 if at all possible. Any info would be great. Thanks.
Matt
tracermc #733282 03/26/2011 5:31 AM
I don't think there was any model number assigned to them. All I have ever heard them referred to is a GM sliding gear transmission because it uses sliding gears instead of syncros. The bolt pattern is different than later Chev or GMC transmissions. The only way it will bolt to a 292 is with some modification or with an adapter.
crenwelge #733340 03/26/2011 3:15 PM
that is all I have been seeing too. I've seen 420 and 435 but those are syncro transmission and they are a longer case. my case is only 9". Thanks for the help.
