0 members (), 94 guests, and 3 robots.
Topics128,093
Posts1,056,474
Members48,444
Hello All,
Melvin, I took your advice and took the door latches apart. I resprung (stretched)the slider springs and reassembled. Some improvement but not good enough. I then noticed the wear on the end of the door handle (square end). I inserted a tap where the bolt goes and mig welded the square where worn. I then ground and filed until the square fit tight with no slop into the latch. This corrected the droopy handle syndrom. Now I realize that mig is soft but at the age of 63 I think it will outlive me.
Way to go APV. I have also heard of a few guys putting the handle in a vice, heating it up, and then twisting it a bit. From the couple I have heard of doing that it worked also.
...yeah, they'll outlive us but we need to leave a little work for someone else later!!
That's what I did Alvin, I didn't use heat,I just had an extra helping of spinach!
Worked fine for me....brute force and ignorance wink
Thanks for the tip APV.
I'm sure others will find it useful. thumbs_up
More pix on Flickr.
