| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 52 New Guy | | New Guy Joined: Nov 2010 Posts: 52 | I intend to NOT use the after market wooden bed blocks, but instead mill some new blocks from a piece of Teflon.
Does any body have the dimensions (Height) of the blocks?
My truck had small pieces of scrap pipe in place of these, when I tore it down, and they were not..uughhh consistent...
so.....any help would be appreciated.
thanks in advance | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | 2-1/4" x 2-1/4" I believe. If wrong someone else will chime in. | | | | | Joined: Nov 2010 Posts: 52 New Guy | | New Guy Joined: Nov 2010 Posts: 52 | Thanks...
I did finally find a reference in the Tech section...tried the forum search and had come up dry..
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I don't think you mean TEFLON, but DELRIN which is used in the auto industry.
Drew
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | What's wrong with the wooden blocks?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Hank
Just took the original wooden blocks off my 51 Panel truck. As rusty as this piece was the blocks were surprisingly nice. Coulda reused them.
I bought the new wooden replacements ( I think they were $16 or $18 ) and soaked them in Thompsons water seal (Used for decks). Should last way longer than me...!
mike
| | | | | Joined: Nov 2010 Posts: 52 New Guy | | New Guy Joined: Nov 2010 Posts: 52 | No actually Teflon.. something like this...working in the oil and gas industry It's a little easier to come by.. http://www.m-p.com/teflon_parts_machined.htmThis stuff wears like iron and is crush proof, and it never breaks down....so it's been on my mind to have a few blocks machined and placed in place of the wooden blocks that's all..just needed the dimensions..thanks for the replies | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Might want to make sure you use filled Teflon as unfilled Teflon is prone to cold creep.
Harold Wilson 41 Chevy 3/4 Ton
