| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Please, I need some help from someone who is familiar with the shifter and linkage on a 49 panel truck. I replaced the shifter a month ago because the old one was sloppy, now the linkage binds more than ever. What I can't seem to discern is this, the shifter rods from the transmission (three on the tree)how much of the linkage rod is supposed to protrude through each of the shifter connections. I find half an inch in the wrong direction and two of the gears are gone. Can anyone help me determine How much of each rod is to protrude through each of the connection to the shifter. Thank you in advance for your help
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Set your trans in neutral, loosen the shifter rods lock nuts on the shifter box, set the shifter arms of the box in the neutral position and retighten the lock nuts.
Drew
| | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Drew:
Thank you, I appreciate it. You are the first to have an answer to a question I have been asking for months.
God bless,
Dave
