4 members (FAST55, Bill Hanlon, Nick in Manitou, 50Chevy3100), 97 guests, and 2 robots.
Topics128,138
Posts1,056,751
Members48,454
#732476 03/23/2011 6:41 AM
I recently came across a complete RPO pcv system off of a '53 2 ton 216. I'm thinking about putting it on my '60 235 that's in my '52 3600. My question is; is it of any advantage or any better than the standard set-up using just the road draft tube? Thanx.
Terry
PS Can someone tell me how to post pictures on this site?
'52 Chevy 3600
'03 Chevy 2500HD
'64 Pontiac Grand Prix
'93 Jeep Wrangler
jacksont #732509 03/23/2011 1:12 PM
A PCV system ventilates the crankcase at all engine speeds, including idle. The road draft tube only works at speeds above 30 MPH or so because it's necessary to create low air pressure around the bottom of the road draft tube to draw air from the crankcase. If the air inlet for the PCV system comes from the "clean" side of the air filter, engine life is increased noticeably because less dust and dirt is drawn into the crankcase by the incoming ventilation air. That was accomplished on engines with vent slots in the valve cover by welding up the slots and providing ventilating air through a vented, filtered oil fill cap or a tube to the air cleaner from the valve cover.
That's a good find. To post pics you need a host site like Photobucket,etc. This will help too.
http://www.stovebolt.com/forum/manual/pictures.html
Drew
I recently found the installation instructions for the PCV system RPO 417. Checking up and down on the site address had more good info.
http://clubs.hemmings.com/clubsites/chevylist/tech/56/417-1.gif
There's an in depth article in last month's Vintage Truck that goes in to detail on the PCV system in the stovebolts.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
