6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#73235 02/14/2007 4:23 PM
Apprentice
Apprentice
Hey guys i realize that the throttle is all linkage to the carb, but whenever you are driving my 65 it sticks and idles real high. You have to reach down and pull the gas pedal up a little and it will idle down. What do i need to look at.thanks
1965 Chevy C-10
All Original
#73236 02/14/2007 4:35 PM
You might want to think about/do isolate the problem. Is it your carb. or is it your linkage. Disconnect your linkage from the carb at the carb. Cycle the carb. with you hand and check for binding. If that checks OK then your linkage must be the problem. Hold the carb. end of the linkage with a silght amount of pressure the have a buddy operate the gas pedal. any binding or snagging? Check your return springs aslo. Broken or weak? It should be easy to isolate and fix. Godd luck.
#73237 02/14/2007 4:43 PM
Apprentice
Apprentice
hey man thanks for the info. We just rebuilt the carb and checked it, but i drove it to work yesterday and it started doing it again so i will do some more looking.
1965 Chevy C-10
All Original
