1 members (53 green 1- ton), 110 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#73232 02/14/2007 3:00 PM
Apprentice
Apprentice
I had my mechanic put a set of 3.38 gears from Patrick's in my 1942 Chev PU. The rear end was a 55T...3.90 rear end from a 1957 Chev. PU...
The problem is the rear differential cover plate will not go over the new gears... Does anyone know if there is a different cover that will work for this...
#73233 02/14/2007 4:04 PM
eek have you talked to Patricks? they're really good about talking over problems .... there's only one factory 3.90 rear in the TF years, and if that gearset is made/sold to replace the gears, and it can be installed in the carrier, it sure oughta fit under the cover!!
I'd give Patrick a call 1st thing today, if you're sure that rear is a 57, and you ordered a gearset for 57 ..... well, actually even if you're not sure grin
#73234 02/15/2007 7:55 PM
Apprentice
Apprentice
Called Patrick's and they said sometimes the rear cover is smaller and will not fit over the new gears...
My mechanic had a welder friend work on the cover and he extended it about 1 inch to the rear.. works great..
The 3.38 replacement really makes a difference in the rpms in all speed ranges...got to help gas mileage and wear on the engine.
