7 members (R&S 51 GMC, Otto Skorzeny, crenwelge, Hotrod Lincoln, 1955 1 Series, Tronman, Wrenchman), 194 guests, and 1 robot.
Topics128,125
Posts1,056,341
Members48,440
I am going to fabricate a stainless steel gas tank and install it behind the rear end, under the bed for safety reasons. I need to determine the hole size and pattern for the sending unit, but dont want to put the old one back in. Do they make replacment units for 45 GMC 1/2 tons?? I want to use the orignal gage, but not sure if new units will be compatible? Anyhelp??
You might just buy the gasket and mark you holes from that.
Good idea. I still need to determine if the original unit's are still available. Should I upgrade and install a later version?
Does anyone know if a 6v negative ground unit can be used in a 6v positive ground vehicle? It seems to me that the polarity should not matter relative to the way a sending unit works.
Is your vehicle 6v positive ground?
Formula1, if the answer to the above is "yes", I have information on a 6v universal unit. It is a sending unit only (the fuel feed would be through a separate line). If you want more information, please email me.
lederman@siena.edu
Tim
Quote
A resistor doesn't care which way current flows through it. It simply reduces the voltage. Any GM 6 volt sending unit from this era should work. If you really want to check, put a good ohm-meter across the senders and compare.
Fred
52 3600
69 C-10
I bought one of these Universal sender from Yogi's Streetrod parts. It works great with my home made tank and original 6 volt gauge. They also have a good selection of tank parts and fittings.
Most of the senders are all five hole mount. The five holes are not evenly spaced so you need to know where the float will go. It should swing to the side and not front to back. Also need to know left or right as some of the senders are fixed. The one above was totally adjustable.
Don't forget to add some bulkheads or baffles in the tank. They will keep fuel from splashing around and let the sender read accurate. When adding the vent hole or tube, make sure it is in the highest end. Mine was not, and fuel would run out if the service station was not level. I ended up with 3 feet of 3/16" steel line tightly coiled up to the under side of the bed and a drain hose off the end of the coil. Joe
JOe,
Thanks for responding to my posting on stovebolt. I checked out the site on the universal sender, and there are 5 or 6 different ones available. How do i know which one to get?? If I change over to a 12 volt system will this change things??
