| | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4 New Guy | | New Guy Joined: Jan 2008 Posts: 4 | Hello, Has anyone done a front disc brake conversion on a 40 1/2 ton? I have an original with 6 lug wheels. I see the conversion sets for sale but they only have 5 lug for a 1940. What else is avaliable? What kind of master cylinder would I need? Proportional valve? Any help would be appreciated. Thanks Gerry | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Get a drop axle from Sid for a 41-54. Then find a set of hubs from a 52-59, and use the kit they sell for the 41-59. Of course you are on your own when it comes to mounting the MC. I got the clutch and brake pedal set from a 1.5 ton 1941 GMC. This pedal setup allows the use of a frame mounted MC.
John | | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | Not to hijack a thread, but will this also work on a 37? | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I believe it would work, however... The 41-54 axles have larger king pins. This is desirable. The width of the axles may vary slightly. the 41-54 axles should bolt in exactly like the 1929-1940 axles, but measuring the spring spacing should be done as a check. | | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | Thanks!! I will measure the spring spacing. | | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | I have converted my '39 to discs with the stock straight axle. I am also using a 2002 4WD Blazer rear axle with rear discs. I originally intended to go with 5 lug 4-3/4" bolt circle wheels, but could not find anything that would work with the stock hubcaps and look right. I sent my front and rear 5-lug rotors and the rear axles to Moser Engineering in Indiana and had them weld up and re-drill for the stock 6-lug pattern. Now I can use my stock 16" wheels with the disc brakes. | | | | | Joined: Feb 2000 Posts: 5,202 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,202 | My 37 has the newer axle with bigger king pins and it was a bolt in swap. Fact I didn't know it was there till I ordered a disk brake kit for a '37 and it didn't fit. The spindles of the newer axle have a larger inner bearing. Then when I replaced the king pins, I figured out it was the bigger axle.
I went with Master Power brakes and use 4 3/4 bolt pattern all around.
What are you guys using for a master cylinder?
I have a Mustang unit with 7/8 bore I think, its takes a lot of effort to stop, but it will stop right now if need be. I am thinking smaller bore for more pressure along with more travel.
Joe | | |
