0 members (), 128 guests, and 1 robot.
Topics128,077
Posts1,056,280
Members48,441
I would like to know if i can put power steering into my 1946 chevy shortbox but still keep my stock front axle?? I found kits for 1949-59 chevy trucks to use 1969-87 chevy 2wd steering boxes, but nothing for 1946. Any help would be greatly appreciated. Thanks
Oh and i would like to put a 350 into the truck, a big reason in me wanting to put power steering into it.
Sounds like you would be better off "stanging" it.
Ive done the research CPP's power steering kit for 47 & up will fit my 38.Will need to cut the mounting bracket no biggie.the frame's are slightly different.As long as the two upper spindle bolts are 7/16 and 3 1/8 inches on center the steering arm should fit.I'll be ordering soon
1937 Chevy 1/2 ton panel
