1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 2 New Guy | | New Guy Joined: Oct 2010 Posts: 2 | will a factory tach from a 1965 v6 truck fit and work in a 64 230 6 cylinder pickup ? | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Not sure, but if one is a GMC and the other is a Chevy, the Dashboards are very different.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | I believe the GMC's all used Sun tachometers, which in that time period used a separate transmitter box. As long as the box was labeled for 12 volts and 6 cylinders it would work fine. The tach didn't care if the engine was inline or a V configuration. As noted above I don't know if the dash layouts are compatible, however early Sun tachometers were assembled with screws and nuts. If the layout requires just the tachometer mechanism, and the V6 version is in fact a Sun model, the mechanism can be easily removed and adapted to the other dash installation with a little creative engineering. | | | | | Joined: Oct 2010 Posts: 2 New Guy | | New Guy Joined: Oct 2010 Posts: 2 | thanks for the info about the control box for the tach. The donor truck is missing control box. I think that sinks my idea to install it.. Maybe I'll have the tach modernized so I don't need a control box. | | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | Those old Sun tachs are hard to find, if it is nice you can find a control unit for it......I just paid $85.00 for one without the sender........it is for my 66 GMC I also found a nos sun bat-o-meter which is really rare to finish off my 66 daqsh.
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
