7 members (stlcardinalsguy, Maybellene, Wally / Montana, Wheelie, Otto Skorzeny, Gdads51, MarkT), 188 guests, and 2 robots.
Topics128,078
Posts1,056,022
Members48,433
#731878 03/21/2011 5:29 PM
with Charlotte swap meet just around the corner i had a question about locating exhaust manifolds or headers. whats the difference between a 235 and 250 inline 6? or how can i tell if someone has a set laid out what they will fit? thanks
john
Major differences. 194-292 series engines were the last of the famous old Chevy sixes and ran from 1963' till the end of production in the early seventies. It is shorter, lighter and smaller overall in size. They looked somewhat the same to the untrained eye but quick inspection will spot the new engines immediately. Four screw valve covers, two piece push rod covers, distributors in the front and not in the middle, different distributors, and they used the V8 bellhousing so trannies would interchange. Internally they had larger bores and shorter strokes, better lubrication and improved head design but still an old Chevy style. I don't think any of the parts will interchange from a 235 to a 194, 230 or 250. Others will provide detailed info if you feel you want it. If I were you and didn't know I'd take a couple of measurements of what you now have and do some checking before purchasing.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Riding in the Passing Lane
53 is right. None of the parts interchange but to see the manifolds by there self its hard to tell the difference. Like he says it would be wise to take some measurements with you. You can't always go by the seller. Never ask "will this fit XXXX.
1972 Chevy c10 Cheyenne Super
I believe you are mainly asking about the manifolds.
216 and 235 intake manifolds are round on the inside, were they attach to the head, 194-292s are rectangle.
My Blog
f John is interested in exhaust manifolds and headers, this page from Tom Langdon's catalog might help. The ports on both the 235 style and the 260 style are rectangular, but the center two siamesed ports (for 2-3 and 4-5) are relatively wider on the 250 style. Carry a spare set manifold gaskets to the swap meets to tell for sure.
Hoyt
