3 members (RLB, Guitplayer, walter74), 96 guests, and 2 robots.
Topics128,055
Posts1,055,783
#731644 03/20/2011 9:45 PM
U
U Offline
Can a t-85 transmission be bolted to a 235 bell housing and if so wouldn't the shift lever be too far back (under the seat)?
ron
uncleb #731656 03/20/2011 10:50 PM
A T-85? Isn't that a stout Ford/Studebaker 3speed overdrive transmission with a non-GM bellhousing bolt pattern?
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
The T-85 was the heavy duty offering on back of the 235 in the task force trucks. Not sure if it was called a T-85, but it was a borg warner case.
Yup, the T85 is primarily a Ford transmission, plus it saw duty in Studebakers and Jeeps. It is not necessarily an overdrive, that was an option on them, same as the GM transmissions. IIRC, the overdrive varaint was the T85N. The bolt pattern is not the same as GM. Better bet would be to use the SM318, as it is a drect bolt in.
Bill Burmeister
I have a correction, as Truckrolet has posted, the T85 was used as the heavy duty offering in Chevrolet and GMC trucks. That one will have the GM pattern. It is also a side shift transmission, operated from the column just like the standard 3 speed. The Jeep version is the only one I'm aware of that used a floor shift.
The GM version T85 was not available with overdrive.
Bill Burmeister
