| | | Forums66 Topics128,033 Posts1,055,531 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 13 New Guy | | New Guy Joined: Mar 2009 Posts: 13 | this is related to previous post by me that got moved so hopefully i'm in the right place now. with some help i've figured out the door vin location and how to find model year and "k" for 4x4. is there also a vin number on the frame to correlate with the door vin? almost forgot, it's a 60-66 gmc. pbly a 3/4 ton.
thanks
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you might find better answers over at Jollys GMC site, they did things a bit different than Chev Bill | | | | | Joined: Mar 2009 Posts: 13 New Guy | | New Guy Joined: Mar 2009 Posts: 13 | i'll check it out.
thanks bill.
scott. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | you won't find a frame vin # in those years on a gmc ron | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Ron - by the 60s even Chevys had frame numbers .... from here: "These numbers can also be found stamped on the Top of the left frame rail in two places, one in the engine bay and the other under the cab." Bill | | | | | Joined: Mar 2009 Posts: 13 New Guy | | New Guy Joined: Mar 2009 Posts: 13 | thanks everyone for the information. not sure whether i'll make an offer on the truck i mentioned but the information will be useful regardless. and smugmug thanks for the pictures, very helpfull. i guess i don't have to worry so much about frame swaps etc since there is no way to track it as long as the frame is the proper application for the year cab. to be honest i am used to fords (have a 63 f250 4x4 stepside) and they have both frame and door matching vin so people like me are a little anal about the numbers matching up. i like any brand of old american made truck though so - gotta get a chevy or gmc. god forbid i might even snag a dodge sooner or later.  thanks again. scott
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | Ron - by the 60s even Chevys had frame numbers .... from here: "These numbers can also be found stamped on the Top of the left frame rail in two places, one in the engine bay and the other under the cab." Bill chevrolets have them but GMC's don't and I did say GMC. don't know why but that is the way it was or is ron | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | perhaps that is a chev frame under that truck. I notice that it has rear coil suspension, not common with GMC but was optional. had to be ordered that way ron | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | even odder Ran, that a Chevy frame wouldn't have the number stamped on it, or would have those other numbers Kieth might do better to contact someone at the 60-66GMC clubBill | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | chev have the nbrs there. that looks like a frame part#n the side of the frame There is a consensus on the gmc board that there is no ser # stamped on the frames ron | | |
