4 members (HandyAndy, Phak1, Otto Skorzeny, mo2cyl), 89 guests, and 1 robot.
Topics128,049
Posts1,055,546
Members48,425
#731590 03/20/2011 6:07 PM
this is related to previous post by me that got moved so hopefully i'm in the right place now.
with some help i've figured out the door vin location and how to find model year and "k" for 4x4. is there also a vin number on the frame to correlate with the door vin? almost forgot, it's a 60-66 gmc. pbly a 3/4 ton.
thanks
you might find better answers over at Jollys GMC site, they did things a bit different than Chev
i'll check it out.
thanks bill.
scott.
you won't find a frame vin # in those years on a gmc
ron
Ron - by the 60s even Chevys had frame numbers .... from here: "These numbers can also be found stamped on the Top of the left frame rail in two places, one in the engine bay and the other under the cab."
My 66 gmc does not have a vin on the frame, top or side, the only place it shows up is over the drivers door frame......Kieth
http://kieth.smugmug.com/Trucks/66-GMC/13311086_gRF57#1218287822_WxqJJ side of frame numbers
http://kieth.smugmug.com/Trucks/66-GMC/13311086_gRF57#1218287733_RYPBg top front location
http://kieth.smugmug.com/Trucks/66-GMC/13311086_gRF57#1218287733_RYPBg top of frame rear
none of these numbers come close to matching a vin # the do show WB and other things.
66 GMC SWB
65 Chevy LWB
65 GMC SWB
918-446-2245
Kieth #732677 03/23/2011 10:42 PM
thanks everyone for the information. not sure whether i'll make an offer on the truck i mentioned but the information will be useful regardless.
and smugmug thanks for the pictures, very helpfull. i guess i don't have to worry so much about frame swaps etc since there is no way to track it as long as the frame is the proper application for the year cab. to be honest i am used to fords (have a 63 f250 4x4 stepside) and they have both frame and door matching vin so people like me are a little anal about the numbers matching up. i like any brand of old american made truck though so - gotta get a chevy or gmc. god forbid i might even snag a dodge sooner or later. smile
thanks
again.
scott
chevrolets have them but GMC's don't and I did say GMC. don't know why but that is the way it was or is
ron
Kieth #732704 03/24/2011 12:24 AM
perhaps that is a chev frame under that truck. I notice that it has rear coil suspension, not common with GMC but was optional. had to be ordered that way
ron
even odder Ran, that a Chevy frame wouldn't have the number stamped on it, or would have those other numbers
Kieth might do better to contact someone at the 60-66GMC club
chev have the nbrs there. that looks like a frame part#n the side of the frame
There is a consensus on the gmc board that there is no ser # stamped on the frames
ron
