3 members (Nick in Manitou, 49 panel, Hotrod Lincoln), 25 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#73159 02/13/2007 3:32 AM
Junior Member
Junior Member
1 Offline
I am new to the older Chevrolet engines. I have a 1954 235 that I overhauled and it runs great. After 100 miles I re-adjusted the solid lifters I noticed very little oil getting to the valve or rocker tip. I would say it is almost dry. Is this normal? Oil is bubling out of the holes in the rockers and out of the overflow tube, but I cant see anything getting to the tip. I am used to seeing oil flip around everywhere like it does on my 350. I have 30+ lbs of oil pressure running 10w30 at a fast idle. I dont see any galling or scoring, but it sure makes me nervous.
"It ain't the years that hurt, its the mileage"
#73160 02/13/2007 5:39 AM
1950 THREE QUARTER TON,
Welcome to the Stovebolt. These old six cylinder engines will not throw oil like their big brothers. What you are seeing is normal. The lube hole through the rocker shafts is on the bottom, so if you see oil bubbling out the top, you know it's doing its thing.
Your oil pressure is great, and the 10w-30 will work fine. The old stovebolts will give you plenty of warning when they need attention...again, welcome. smile
Stuart
#73161 02/13/2007 4:18 PM
Sometimes you can get more even flow across all rocker arms by lightly losening one or more of the bolts holding down the entire assembly.
This can be done while idling and with higher rpms to check flow at higher oil pressure.
If everything else is to spec, the rockers get just enough oil, but no so much that it splashes all over.
The valve guides also need only the slightest amount of oil.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
#73162 02/14/2007 3:28 AM
you can pinch the over flow tube down a bit....seen it done that way many times..
#73163 02/14/2007 4:34 AM
Junior Member
Junior Member
1 Offline
Hey, I appreciate the advice. Like I said, I love the old engine and I would hate to wound it by doing something wrong. It taps a little here and there but I was told that pretty much all of the solid lifter engines will make a little more noise than a hydrolic engine. I think it gives the old engine some character! Thanks again.
#73164 02/14/2007 3:20 PM
1950, It sounds like your oiling properly and like Darin367 said pinching off the overflow tube will increase the flow. You want the rockers to tap a little, better to loose then tight to avoid burned exhaust valves
1949 Chevy 6400
1931 Chevy Firetruck
