2 members (Guitplayer, Lostbuthaulinass), 136 guests, and 1 robot.
Topics128,048
Posts1,055,540
Members48,425
#730816 03/17/2011 11:20 PM
need help with ID of this engine.... its a1950 3/4 ton.. number on side of block 3693374 its got a GM with a 48 in a circle right above the the block number and a 10 right below it and a 235 on the oil pan
toddvan #730829 03/18/2011 12:09 AM
toddvan,
I could not find information on that block code. Someone else will most likely post information.
Here are location of other codes that should help to ID your engine. Post the codes and people will try to help.
The oil pan is from a low-pressure 235. They were made from 41-53.
tclederman #730833 03/18/2011 12:49 AM
thank u sir.... i will try to find the other codes on my motor
toddvan #730848 03/18/2011 1:55 AM
The inliners.org casting code lists show that block to be a 1942-49 235. I have seen heard, and have seen some photographs, that the oil pans for those early 235s had a "235" stamped in the sheet steel on the side of the pan. Those engines had the same bore and stroke of the later 235s, but used the low-pressure lubrication and high push rod cover as the 216s.
Hoyt
hoyt #730879 03/18/2011 3:11 AM
You won't get better info by posting twice.
Cletis #730982 03/18/2011 2:38 PM
Cletis, I noticed that too after I responded to the other post. Funny. grin
Drew
hoyt #731437 03/20/2011 3:33 AM
thanks for ur reply
