2 members (Gdads51, 55shaker),
166
0
Mod | | | Forums66 Topics128,048 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 6 New Guy | | New Guy Joined: Mar 2011 Posts: 6 | need help with ID of this engine.... its a1950 3/4 ton.. number on side of block 3693374 its got a GM with a 48 in a circle right above the the block number and a 10 right below it and a 235 on the oil pan
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | toddvan, I could not find information on that block code. Someone else will most likely post information. Here are location of other codes that should help to ID your engine. Post the codes and people will try to help. The oil pan is from a low-pressure 235. They were made from 41-53. | | | | | Joined: Mar 2011 Posts: 6 New Guy | | New Guy Joined: Mar 2011 Posts: 6 | thank u sir.... i will try to find the other codes on my motor | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | The inliners.org casting code lists show that block to be a 1942-49 235. I have seen heard, and have seen some photographs, that the oil pans for those early 235s had a "235" stamped in the sheet steel on the side of the pan. Those engines had the same bore and stroke of the later 235s, but used the low-pressure lubrication and high push rod cover as the 216s.
Hoyt | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You won't get better info by posting twice. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | You won't get better info by posting twice. Cletis, I noticed that too after I responded to the other post. Funny.
Drew
| | | | | Joined: Mar 2011 Posts: 6 New Guy | | New Guy Joined: Mar 2011 Posts: 6 | | | |
