5 members (KEVINSKI, Leo, Hanks custodian, greenie-reddy, Hotrod Lincoln), 88 guests, and 2 robots.
Topics128,128
Posts1,056,666
Members48,450
#731187 03/19/2011 4:26 AM
My wife and I just got a '66 C25 3/4t 4x2. I want to make it 5 lug. What kind of donor truck can I use to make this as easy as possible? And as cheap as possible? "Haha"
Any kind of help would be greatly appreciated! Thx.
Why go 5 lug? You have to change the entire rear axle and a bunch of stuff in the front end.
If you want a 1/2 ton ride just put 1/2 ton coils in it.
The glass is twice as big as it needs to be.
if thats what you want, switch out the front cross member with 71-87 1/2 ton. you will also get disk brakes with those. as far as the rear, im not so sure about spring perches and shock mounts being the same width spacing.. but 71 and newer apply to the 5 lug as well of course.. the newer the body style truck it came out of, the wider the mounts will be from each other.
everybody is ignorant @ something.the more we work together, the less ignorance there is floating around
