6 members (JW51, 55shaker, moparguy, Cosmo, Gdads51, 1 invisible), 108 guests, and 2 robots.
Topics128,069
Posts1,055,896
Members48,428
#73116 02/12/2007 10:47 PM
Have hooked up the Offy linkage kit I bought from Tom Langdon to my two Holley Webers. First had a problem with the crank arms trying to rotate around the shaft. Ground a little off of those where the bolt and nut crank down to get them a bit tighter. Now, with everything hooked up, when I step on my gas pedal, I only have about 1 or 2 inches of pedal travel before the carbs are at full throttle. Am I missing something in the way I set the linkage up? Would like a bit more pedal so I don't go from 0 to 60 instantly.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
Might take a look at the bellcrank...move the vertical rod in towards the pivot point. That should alter the vertical movement of the rod that connects to the linkage. Doesn't cost anything to drill another hole and it might just do the trick.
I replaced the philips head bolt with a 7/16-20, cut out the opening so I could get more squeeze!
When I get it the way I want it I'll put a little tack weld on the underside of it. Don't see any reason why I'd be wanting to ever take it apart once it was set up correctly. However, that 0-60 instantly sounds like it might be fun!!!!
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
I have the same setup and have full pedal travel of about 2+". I agree that the bellcrank is the culprit. When you say 1 or 2 inches you are allowing a 100% leeway. One is not enough but two is all there is (approx)and it makes a big difference where you are measuring it at. Two on the pedal is about right but that translates to something less on the vertical rod, at least on mine.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Well, I'll measure the actual pedal travel this weekend and if it's at or near 2", I'll give it a chance. If not, maybe I'll try the extra bellcrank hole. Seems that once I cut out some of the opening on the shaft linkage arms, they bolted down much more tightly as well.
49,
I was wondering if you are experiencing any heat realted issues with the fuel block so close to the fentons? Maybe not this time of year. What about the carb jetting?
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#73121 03/06/2007 10:13 PM
Wow, just getting back to this. Wasn't satisfied with the tightness of the linkage from the pedal to the bellcrank and then up to the throttle shaft lever arm. Will post some pics this weekend of the neat fittings I bought to align the linkages and make the action smoother.
Kent: I have not run the truck on the road as yet but I think that the fuel log will be okay where it is. Being attached to the Offy intake and actually standing off of that by 1/4" or more should get me plenty of air movement. Will see when it's 95 degrees out!
