7 members (Gray_Ghost, JoergK., Peggy M, oldieoldie, dbwr, 2 invisible), 186 guests, and 3 robots.
Topics128,191
Posts1,057,348
Members48,469
#731122 03/19/2011 12:25 AM
PPG omni au MTK 2k urethane paint, got 3 gallons of it that have been sitting 4 years in hot and cold (freezing) garage. Is it still usable with a good mixing? Haven't opened cans yet. Thanks for any info!
[email protected]
62 burb
R.I.
Ex Hall Monitor
Ex Hall Monitor
I would be more concerned about the age over the temp it was stored at unless the temp was well below 0. The warehouses paint is stored in normally aren't heated. A call to PPG customer service should answer your question factually.
If the paint was air tight, and never opened, You should be fine...Now, in enamel, if the paint has hardened, of course You pitch it...Lacquer, add thinner, and You can bring it back...If You are spot painting, then You more than likely went over on thinning the paint, and naturally have a mismatch...If a viscosity cup is used, You would be OK...22 seconds is the right mix..
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
Not if the paint has been frozen, sorry...Eric
Currently working on custom metal and How to videos.
1949 and 1972 chevy trucks
70 chevelle SS455
Pictures of my work and projects
http://community.webshots.com/user/sevt_chevelle
