1 members (Nick in Manitou), 159 guests, and 8 robots.
Topics128,077
Posts1,056,032
Members48,433
#73109 02/12/2007 6:07 PM
Have a 1965 292ci and recently changed oil (went from 30wgt to 10-30) and noticed slight change in pressure, use ta' idle at 30psi and now is at 25. Also oil filter is shorter than what use ta' puttin' in (Napa says I'm good). Would these changes cause pressure ta' drop? Am sure I'm O.K., but would like second opinions. Pre-thanks in order.
"There's no head like Steelhead" wink
#73110 02/12/2007 6:35 PM
It doesn't sound like a problem to me. Probably just due to the change in oil viscosity. 25 at idle is good pressure in my opinion.
#73111 02/12/2007 6:56 PM
sounds fine to me too, a 235 I have only pushes about 10-15 at idle grin
#73112 02/12/2007 6:57 PM
53,
Thanks for the quick come-back. That is what I was thinkin', viscosity. Thanks again and have a good one.
#73113 02/12/2007 7:13 PM
Bill,
Thanks much and sounds good ta' me. ~Skip
#73114 02/12/2007 9:47 PM
Riding in the Passing Lane
Either oil filter is O.K. Some space requirments you have to use the short filter. If you have room next time I would use the longer one. It is for v-8,s. If it smokes or uses oil you may have to use a heavier oil like 10/40 or 15/40. A lot of people are going to the 15/40 desiel oil. It has more protection for the flat tappets.
1972 Chevy c10 Cheyenne Super
#73115 02/13/2007 4:09 PM
Wrench,
Thanks for the response and will keep an eye on any changes w/ engine ie., oil leaks, etc',.
Thought that I could possibly have some problems what with switchin' over to a variable wgt oil.
Right now she looks pretty good (knockin' on wood). ~Skip
Will keep in mind your recommendation on the other variable wgt's.
