0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73107 02/12/2007 5:50 PM | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | Finally got my latest ebay find home yesterday, a nice low rust (for Illinois) 1970 C-10. The 3 on-the-tree shifter doesn't engage anything in the forward-backward neutral position. It appears to only go into 2 and 3, no R or 1. Where should I start looking for the problem? It seems like it is probably something not engaging inside the steering column or maybe something broken on the shift lever. Any suggestions on where to start? Hopefully I can get it in the garage this weekend to melt the snow and see if I can get her moving down the road (after the snow/salt season, of course).
53 Dumpy
1951 Chevy 3100 "Ernestine" 1970 Chevrolet C10 "Ol' Blue" 1940 JD "long-hood" B 1959 Jeep FC-170 1960 IH B275 2013 Chevy Silverado 2023 GMC Denali 2500HD
#73108 02/12/2007 6:33 PM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Get yourself a helper and have them shift into 2 and 3 while you watch the levers on the steering column by the exhaust manifold. One of the levers should move up and down while shifting, then have them shift between R and 1, the other lever should move up and down. If it moves, then look underneath where the rods attach to the levers on the trans and go through the same procedure. If you see movement there, the problem is inside the tranny, possibly a broken shifter fork. | | |
