| | | Forums66 Topics128,174 Posts1,057,048 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | I found a couple of posts relating to this but wanted to get more feedback on who has installed their 'new' firewall pad in an assembled AD truck. I'm not restoring my '53 3100 yet, just gutting and replacing the mouse nest infested and torn interior pieces...which is everything. I will probably remove the heater but was hoping that would be it. Thanks.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Allan,
The main items that you will have to deal with are cables/wires that go from under the dash through the firewall. You could cut "slits" in the cover from the top edge downwards; or, you could disconnect those wires/cables on the engine side of the firewall and pull them back through the firewall (and back through the old pad, if it is still there).
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I found a couple of posts relating to this but wanted to get more feedback on who has installed their 'new' firewall pad in an assembled AD truck. I installed The ABS style firewall pad in my 50 ...picture link... There is some trimming involved. It’s thick ABS with Jute backing. Tuff stuff It would not be enjoyable with everything "assembled" Good luck
| | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Good tips and great photos. I think I will take Tim's advice and do what I can to pull wiring and cables back through...after labeling of course...  Thanks.
