2 members (55shaker, 1 invisible),
55
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 2 New Guy | | New Guy Joined: Feb 2011 Posts: 2 | i just tried to install the frame mount bracket that i bought from speedway motors and it's no where near right. the brake pedal would be over where the original gas pedal was. has anyone ran into this and how did you fix it? i'm wondering if i got the wrong part? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Welcome,
Any more details? What make, model and year truck? What part number for the bracket you bought or what might it fit?
Have you asked the vendor you bought the part from what they think? | | | | | Joined: Feb 2011 Posts: 2 New Guy | | New Guy Joined: Feb 2011 Posts: 2 | sorry its a 53 3100 and i just went back and looked at my invoice and apparently i ordered or received the wrong one, so that answers my question thanks! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Good luck! Mine came from CPP. From what I hear they all take a little "adjusting" to make the fit, but yours does sound like a screw-up.
~Jim
| | | | | Joined: Nov 2009 Posts: 33 New Guy | | New Guy Joined: Nov 2009 Posts: 33 | I just installed the one I got fronm speedway motors bolted right in. The quality is good. might hve to tweek the angle of the pedal arm to use the original hole. BUT since I have to replace the floorboard I think I will handle it that way. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I believe there is always some "tweaking" to be done. But we wouldn't have it any other way.
~Jim
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I think Big Chevy is right. I can't think of any aftermarket mod I've done that worked right out of the box. And I also agree with him, that's the fun of it. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | For those of you that need to align the clutch and brake brackets, they will "bend" enough to lineup with the floor holes. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I'm wondering if you're mounting it in the correct holes. Got a picture? If you do, I'll compare it to mine.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
