2 members (1955 1 Series, Otto Skorzeny), 159 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
#73032 02/11/2007 6:01 AM
Hello Wise Ones, Still researching my rearend options and came up with another question. Is there a whole rearend form another truck..or car that would somewhat "bolt" in or at least be an easier mod then a overdrive. right now I'm going to getting the 3.38 gears for my truck (1960 C-10, 4spd) but I would like to see if I can find one with a bit lower gear ratio. I wish I had the 3spd on the tree I'd just get a OD tranny and bolt it right up but I haven't been able to find a OD tranny with the same length tailhousing as mine! uggh. (have the short tailhousing as most of you know with the 4 spd OTF) So once again I seek your words of wisdom, thanks! -Danny
Thanks,as always -Danny
1960 C-10 Stepside,Longbox
235,4spd 3.90 diff.
#73033 02/11/2007 7:28 AM
A GMC of the same year came standard with a 3.07:1 Spicer. It should bolt right up to your Chevy suspension. Make sure the one you get is 3.07 because there were lower geared options.
#73034 02/11/2007 4:27 PM
Riding in the Passing Lane
I recently put a 3.08 from a 67-70 truck in my partners 60 c10 panel. It took a bracket kit & adjustable panhard bar. It took a high qualified welder to put on the brackets. Worked out real good. What about an s-10 5 speed. That,s what i put in mine. Getting the driveshaft modified is no big deal.
1972 Chevy c10 Cheyenne Super
#73035 02/13/2007 5:10 AM
Quote
So would a GMC from 1961-62 work as well?
235,4spd 3.90 diff.
#73036 02/13/2007 6:02 AM
As far as I know, the rear suspension is the same on 60-66 GMC and Chevy. The GMC housing from any of those years should bolt up.
#73037 02/13/2007 11:54 AM
My '62 Chevy half ton had coil springs;my best friend's '63 GMC half ton had leaf springs. Maybe one or the other was offered with either set up available,but I was always told the Chevies were coil,the Jimmies were leaf. Like wrenchbender says-it just takes a bracket kit to make the swap. no big deal. I had a 3.55 posi from a '69 four wheeler swapped into my first '62,it took the guy about 3 hours,cuz he cut the mounts off my old axle and welded 'em onto the new one.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#73038 02/13/2007 2:54 PM
The G.M.C.s used leaf springs. Most Chev,s had coils although the leafs were an option.
#73039 02/15/2007 4:11 AM
Not to start an argument but the only one I have to go on is a GMC with coil rear suspension. I don't know the year model but it has the wrap around windshield.
#73040 02/17/2007 4:33 AM
OK, after doing further research on 6066 GMC Guy , I find that '60-'62 GMCs had coils. My parts truck is a '60 or '61.
#73041 02/17/2007 6:17 AM
My understanding is that during the time when the standard on a Chevy was coils and the standard on a GMC was leafs, that both were available the other way. I've not confirmed that, but most likely you can find examples of both if you look long enough.
#73042 02/17/2007 3:49 PM
Jim & Caroline
