7 members (Phak1, GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, 1 invisible),
123
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,072 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73032 02/11/2007 6:01 AM | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | Hello Wise Ones, Still researching my rearend options and came up with another question. Is there a whole rearend form another truck..or car that would somewhat "bolt" in or at least be an easier mod then a overdrive. right now I'm going to getting the 3.38 gears for my truck (1960 C-10, 4spd) but I would like to see if I can find one with a bit lower gear ratio. I wish I had the 3spd on the tree I'd just get a OD tranny and bolt it right up but I haven't been able to find a OD tranny with the same length tailhousing as mine! uggh. (have the short tailhousing as most of you know with the 4 spd OTF) So once again I seek your words of wisdom, thanks! -Danny
Thanks,as always -Danny
1960 C-10 Stepside,Longbox 235,4spd 3.90 diff.
#73033 02/11/2007 7:28 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A GMC of the same year came standard with a 3.07:1 Spicer. It should bolt right up to your Chevy suspension. Make sure the one you get is 3.07 because there were lower geared options. | | |
#73034 02/11/2007 4:27 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I recently put a 3.08 from a 67-70 truck in my partners 60 c10 panel. It took a bracket kit & adjustable panhard bar. It took a high qualified welder to put on the brackets. Worked out real good. What about an s-10 5 speed. That,s what i put in mine. Getting the driveshaft modified is no big deal. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#73035 02/13/2007 5:10 AM | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | Originally posted by cletis: A GMC of the same year came standard with a 3.07:1 Spicer. It should bolt right up to your Chevy suspension. Make sure the one you get is 3.07 because there were lower geared options. So would a GMC from 1961-62 work as well?
#73036 02/13/2007 6:02 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | As far as I know, the rear suspension is the same on 60-66 GMC and Chevy. The GMC housing from any of those years should bolt up. | | |
#73037 02/13/2007 11:54 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | My '62 Chevy half ton had coil springs;my best friend's '63 GMC half ton had leaf springs. Maybe one or the other was offered with either set up available,but I was always told the Chevies were coil,the Jimmies were leaf. Like wrenchbender says-it just takes a bracket kit to make the swap. no big deal. I had a 3.55 posi from a '69 four wheeler swapped into my first '62,it took the guy about 3 hours,cuz he cut the mounts off my old axle and welded 'em onto the new one. Speed | | |
#73038 02/13/2007 2:54 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The G.M.C.s used leaf springs. Most Chev,s had coils although the leafs were an option. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#73039 02/15/2007 4:11 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Not to start an argument but the only one I have to go on is a GMC with coil rear suspension. I don't know the year model but it has the wrap around windshield. | | |
#73040 02/17/2007 4:33 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | OK, after doing further research on 6066 GMC Guy , I find that '60-'62 GMCs had coils. My parts truck is a '60 or '61. | | |
#73041 02/17/2007 6:17 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | My understanding is that during the time when the standard on a Chevy was coils and the standard on a GMC was leafs, that both were available the other way. I've not confirmed that, but most likely you can find examples of both if you look long enough.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#73042 02/17/2007 3:49 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
