| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | I'm in the process of painting the frame and inside of front fenders. I've read here POR 15 is a very good choice. I just have the problem that where I live POR is not available and importing it since it is considered dangerous material, is sort of out of the question. Any other options? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Zero Rust? excellent and non-toxic, but maybe you can't import any kind of paint? then maybe Tremclad or Rustoleum is available locally, both give good results [common owner now] with proper prep Bill | | | | | Joined: Jan 2006 Posts: 29 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 29 | YES POR-15!! I used it on my 59 GMC. I sand blasted my frame, air hosed it off, cleaned with brake cleaner and BRUSHED on the POR-15. It looks great. You can order it from Summit Racing. Have fun with it!! | | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | I'll try what Bill suggests. Does those spray liners might work to protect the frame? Give it another hand of color over the liner?
Problem with ordering from US is that paint is considered dangerous (no air delivery) and by boat is an extremely long and hard paper work. By land, well, it might get kidnaped by the Zetas in México. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Have you checked locally on what the auto paint shops in the Guatemala area use? Do you have a local auto body paint supplier in your area? Trailer builders and truck repair shops should have a product they use. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | ive used tractor supply implement paint on one frame and XO RUST on another frame with good results without the high cost of shop paint. | | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | Thanks, I'll shop around and see what I can find. Keep you posted. | | |
