0 members (), 171 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#728533 03/10/2011 11:25 AM
Well i got about an egg sized hole on the driver side of my roof. The bottom of the whole meets the lip that runs around the top of the cab on my 66 GMC. This is an immediate repair im wanting to do and will be tackling it by myself. So im just wondering what you guys would do and some dos and donts for this kinda repair....Also what kinda damage and things do i need to look for from this hole thats been there for who knows how long.
1966 GMC
Do you best in getting the a matching patch as far as the gauge of metal (from another truck would be ideal). You have to make sure you "tack" it. You must keep from warping the roof. Clean the rust, if any, the best you can. I you can spray and rust converter in the hole, I would. Good luck and be patient.
Thank you for your time,
DADZ59
"GUNNY" USMC ret.
MP Rios
775 560 7145
[email protected]
"Whatever It Takes" 1st Bn 4th Marines
www.stovebolt.com/gallery/rios_michael_1959.html
DADZ59 #730065 03/15/2011 5:11 AM
Most likely you will be dealing with rust, hopefully it did not travel to the window post or other areas. You will have to remove the headliner and grind both sides of the damage. Contact one of the sellers in the swap meet section for a patch panel so you have an exact match and carefully trace out the area to be removed. Die grind and then tack weld making sure you do not warp the metal. There is lots of information on this process. Good luck!
