5 members (HandyAndy, Ponchogl, dt235sd, mason86, Cosmo), 112 guests, and 2 robots.
Topics128,047
Posts1,055,662
#721851 02/17/2011 5:58 PM
I want to install an underbed gastank for my 54 chevy 3100. Soon I want to mount it to a 1964 Chevy Frame. What would be a good tank to use? Is there one I can get from a donor vehicle that will fit nicely? or would I have to get a new one?
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
You may want to ask this in the 60-66 Forum. Most of us are creature of habit and go to the same places and seldom look elsewhere. So the guys who may have done this would have a better shot at seeing your post.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
The back part of the frame either a 54 or 64 should be the same since the beds are the same.
The only caution i have is be sure that the tank is located in such a way that it can be removed without removing the bed. mine was installed with mounting flanges on the top of the rails. now that i want to install new bed wood the tank has to be dropped. or if you have to change the sender same thing.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
what gas tank did you use?
I am right now in the process of installing a tank from 83/87 subaru not sure witch model i picked it up about 5 years ago and now the tank shop is closed so i am unable to find out for sure.It fit's nicely up in the spare tire pocket and has the one wire sending unit. Only thing i don't like is that it will show from the rear below the bumper. I guess i will go with it for now and keep an eye out for something better.
layback
I've got a frame mounted tank from a 47-48 if you're interested.
Robert C.
I'm a Genius in the making.
1950 3600
Beast 54 I used a tank from a 83 el camino between the back rails of my 49 suburban. I had to slightly massage the seams which stick out an inch or so but no leaks so all is well. It has fuel pickup in the top and a side mounted neck which I will run out to the fender. So think about chevelles, etc in that year bracket. Problem is first things most yard do is punching holes in tanks for insurance purposes.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
check your PM mobileortho
The company i got my tank from is out of business now.
2017 Buick Encore
See more pix
Mobileortho,
Do u still have your '47/'48 tank and if,do you want to sell it?
Thanx,
Mike
