7 members (John Dlugos, klhansen, Bill Hanlon, Gray_Ghost, Otto Skorzeny, 2 invisible), 218 guests, and 2 robots.
Topics128,101
Posts1,056,179
Members48,436
I'm planning to put a '59 cab onto a '77 frame on a future project. The '77 wheel base is about 3.5" longer than the '59 so I'd like to stretch the cab that amount to gain some leg room. I'm not too tall to fit in but I do have some back problems so a little extra room helps. I haven't found any sources of detailed instructions for doing something like this. I'm just an amateur but I like challenges. My plan is to add the 3.5" just behind the door from the drip rail down and to put it near the middle on the roof. I've seen where people have added length by stretching the doors but I think that might be more difficult. I have a wrecked 55.2 panel that I can cut pieces out of to splice in. Any advice from people who have done this will be appreciated. Also, if you can point me to any good sources of info on the web or any books that would help. Thanks again for your help.
Jeff
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
I do not think 3.5 " is worth all that trouble, 12-18" would gain a lot of room, this is not for the the faint of heart.....only the exxxxperienced would try this....Kieth
66 GMC SWB
65 Chevy LWB
65 GMC SWB
918-446-2245
Here's some information on a AD truck being extended by a member, maybe this will help.
1948 extended cab with pictues
finished view
Thanks GMONIZ, that's similar to what I want to do except he streteched his doors too. It looks like he added about 6" to his. I'm not looking for storage space, just a little leg room. According to my measurements, 3.5 to 4" will make the interior dimensions very similar to a later model standard cab, which I find comfortable enough. It also won't be noticible to most people that the truck has been modified. I don't think my back could take much driving in a standard TF cab. I have a '57 1-ton that I drive only for short trips so I know what it feels like.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
I thought the guy who stretched the cab through the doors was great! It gave the truck a chopped look without loosing headroom. If I ever stretched a cab on a AD truck, I would definitely add to the "entrance" portion of the cab.
Here's a previous discussion on the topic Unfortunately some of the picture links do not work. You will find a couple of different styles of extending the cab
You know just because he added 8" you don't have to, you can just add the 3 1/2" through the door, it would be a subtle difference that no-one would notice
Check out Mongo's PROJECTS For more pictures of his extended cab
