| | | Forums66 Topics128,268 Posts1,058,379 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 25 New Guy | | New Guy Joined: Mar 2011 Posts: 25 | Well i got about an egg sized hole on the driver side of my roof. The bottom of the whole meets the lip that runs around the top of the cab on my 66 GMC. This is an immediate repair im wanting to do and will be tackling it by myself. So im just wondering what you guys would do and some dos and donts for this kinda repair....Also what kinda damage and things do i need to look for from this hole thats been there for who knows how long.
1966 GMC
| | | | | Joined: Jan 2006 Posts: 29 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 29 | Do you best in getting the a matching patch as far as the gauge of metal (from another truck would be ideal). You have to make sure you "tack" it. You must keep from warping the roof. Clean the rust, if any, the best you can. I you can spray and rust converter in the hole, I would. Good luck and be patient. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Most likely you will be dealing with rust, hopefully it did not travel to the window post or other areas. You will have to remove the headliner and grind both sides of the damage. Contact one of the sellers in the swap meet section for a patch panel so you have an exact match and carefully trace out the area to be removed. Die grind and then tack weld making sure you do not warp the metal. There is lots of information on this process. Good luck! | | |
